Host get disconnected and reconnected periodically
Hi guys, hosts in my network get disconnected and reconnected periodically every 2 hours. What settings should I look into to fix this issue?
First of all describe topology and what kind of disconnects you experience (is it ethernet/wireless disconnects, DHCP lease expiry, connection breaks, …).
If there’s a central Mikrotik device which suffers, post complete configuration (as printed out by executing command /export hide-sensitive from terminal window - post it here inside [code] [/code] block).
