hostname problem
Hi all…
any suggestion about make ping or search files from one computer to other by hostname? this is the scenario:
pc Frank ---------mikrotik bridge---------pc John = don’t
pc Frank ---------simple switch---------pc John = done
I modified the host file in the computers… all good but if the network has 200 pc
thanks and regards
I assume simple bridge should work fine for the same configuration (when two interfaces are bridged, where users are connected).
Do you get it to work with IP address?
yes it works
