Hi all, I am newbie I am tring to set my first hotspot using 2 MT board without success, if anyone can help me because I am becoming crazy, the boards are is the same room and from the client I can scan the MAIN AP SSID=wlan3, here my configurations but I can't ping from client to AP and viceversa.
Thank you in advance Giuseppe
MAIN ACCESS POINT RB333
[admin@MikroTik] > interface wireless print
0 R name="wlan1" mtu=1500 mac-address=00:15:D6:05:06:26 arp=enabled
interface-type=Atheros AR5213 mode=ap-bridge ssid="wlan3"
frequency=5500 band=5ghz scan-list=default antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=wds-bridge wds-ignore-ssid=no
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
[admin@MikroTik] > interface print
Flags: X - disabled, R - running, D - dynamic, S - slave
NAME TYPE MTU
0 R ether1 ether 1500
1 X ether2 ether 1500
2 X ether3 ether 1500
3 R wlan1 wlan 1500
4 R wds-bridge bridge 1500
[admin@MikroTik] > interface bridge print
0 R name="wds-bridge" mtu=1500 arp=enabled mac-address=00:0C:42:1D:8E:7C
protocol-mode=none priority=0x8000 auto-mac=yes
admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s
transmit-hold-count=6 ageing-time=5m
[admin@MikroTik] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST
0 ether1 wds-bridge 0x80 10
1 wlan1 wds-bridge 0x80 10
[admin@MikroTik] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.2.12/24 192.168.2.0 192.168.2.255 wds-bridge
CLIENT CONFIGURATION
0 R name="wlan1" mtu=1500 mac-address=00:0B:6B:4E:DC:A6 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="000B6B4EDCA6" mode=bridge ssid="wlan3" area=""
frequency-mode=manual-txpower country=italy antenna-gain=0
frequency=5500 band=5ghz scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R ether1 ether 0 0 1500
1 R wlan1 wlan 0 0 1500
2 R wds-bridge bridge 0 0 1500
0 R name="wds-bridge" mtu=1500 arp=enabled mac-address=00:0B:6B:4E:DC:A6
stp=no priority=32768 ageing-time=5m forward-delay=15s
garbage-collection-interval=5s hello-time=2s max-message-age=20s
0 ether1 wds-bridge 128 10
1 wlan1 wds-bridge 128 10
0 192.168.2.128/24 192.168.2.0 192.168.2.255 wds-bridge
