Hot Spot
At the moment we are set up as a big bridge, But we are wanting to route the whole network. We have one problem . I have a hot spot router that does all our hot spot authentication at the main spot where we have the t-3 line and the wan router.How can i route the whole network and at the access points have customers that are set up static and still have it where if a new customer opens there lap top at any tower they will receive the hot spot login in page . All towers run Mikrotik but the Hot Spot Router is not Mikrotik it is a Colubris hot spot router. Can this be done or do i have the leave the network as a big bridge.
You could get another mikrotik router for your noc and setup your ap to route all unknown traffic through an eoip or vpn tunnel back to it and then on to the hotspot gateway. Actually any vpn concentrator should work.
Dan
Been trying to set that eoip up . Can get it to ping the other side but cant run thru it . Not sure how to set that up any ideas.
Its been a while since I looked at the documentation about it, are you running this through a vpn link? IIRC there was something about running it through a vpn tunnel. I’ll have to look at the documentation as see what I can make of it. Can you post your configuration so far?
Dan
