Hot spot
I have been trying to get hot spot to work.
I can conenct to the hotspot and acces the internet and all network activities.
How do i make it sothat you have to login?
And how do i get to a login page?
http://www.mikrotik.com/testdocs/ros/2.9/ip/hotspot.php
So i need some sort or user database.
Like radius!
Does the RB433 has a radius SERVER or does it only connect to a radius server?
Do you have to download a server software like freeRadius ? does this run on the board or a pc server?
Cant i jusy have like 10 or 15 users on the rb433 and the hot spot just allows those few?
yes. follow the manual given
i did.
but when i go onto the internet it just works.
and if i try access the hot spot //hotspot or 192.168.1.2 it like loads then gives me the internet explorer no connection error.
Is a hotspot the easiest way to manage a mini ISP.
I want to provide internet to a few people in a rural farming area and each client will have a CPE that connects to a rb433 . Whats the easiest way to manage how much internet they will use? and so that not any one can jus login? i was thinking hotspot?
I am busy following that tutorial.
I can Connect to the hotspot and i can get an Ip from its DHCP.
But i still dont get asked to login when i try go on the internet?
is ther meant to be a bridge any where? or does the hotspot act as a bridge?
Post your configuration.
how do i do that?
  1. first configure your router that the internet works fine without hotspot
  2. then run the hotspot setup
watch this video: http://www.tiktube.com/index.php?video=53
if this video can’t help you, nobody can
