Hot to check if variable is defined
Hello, my question is as in topic. In MT 2.9 it was easy:
:if ([:len $my_variable] = 0) do={:global my_variable 0}
How to do the same in MT 3.x ?
You must declare all variables before you use them in V3.
This will make the global variable called my_variable available to the script.
:global "my_variable"
-Louis
