Hi there i am trying to forward all ssh requests on port 222 to go to port 22. But im having some trouble.
Here is the rule that i have added.
The reason why i want to do this is so that i can log into router if i have locked myself out.
I stil want to allow port 22 for admin users.
ip firewall filter add chain=input action=accept src-port=222
dst-port=22 protocol=tcp
Change X to the line number of the new rule, and x.x.x.x/y to the ip/subnet of the remote computers that should have unlimited access to the router OS. This new rule should be the first rule in your filter.
Sorry to butt in, but this can be done with one line:
ip firewall nat add dst-address-type=local dst-port=222 protocol=tcp action=redirect to-ports=22 chain=dstnat
That said I agree that you should rather either whitelist an IP block like Tim described, or look up port knocking (there was a US MUM 2010 presentation on it with great detail), or look into VPNs.
Fewi is correct about port knocking. I use a Blackberry, and the ip changes as I move from provider to provider. It allows me to port knock and get in from anywhere.
I did not see the MUM presentation, but I use “mousetraps” on the ports immediately above and below the port knock port. If you hit one of those first (port scanning), you are blocked for a day.
