Can anyone recommend the best 802.11 AP to use in a hotel?
mm ![]()
you can try with Routerboard. ![]()
good joke
We use the senao 2611 AP3s, But, we are having problems with some MACos computers and some Dells. It looks like a chip set issue.
Silly question (perhaps), but why are people NOT using an MT powered solution?
Is it just down to cost?
Regards
When you are using Mikrotik OS to do DHCP or Hotspot for the client, I think it’s better to use one the high power interface, such as Prism 300 mWatt PCMCIA, or SR2 miniPCI card. The price for those cards are cheaper than a good 2,4 Access Point hardware.
I do want to use MikroTik/Routerboard but need to know what ap/antenna would have the best coverage.
That question, especially regarding the antenna, can not be answered without seeing the building and doing a site survey and some testing. So you decide…
–Tom
