Hotel Internet Management
Guys I need your recommendation/Experience
we have a hotel where it needs efficient way to charge internet
I’ve installed Mikrotik RouterBoard for them . is there a way to integrate Mikrotik with Billing software
or even integrate it with PMS such as Opera.
Regards,
well i suppose it depends where you are.
i would look at a software called radiusmanager, see if it’ll offer the right billing options that you need.
if it does then it is as simple as using the hot spot system with mikrotik and have it authenticate through the radius box
