Hotspot : >1 login using same username at any 1 time.
Can anyone tell me where is the control to
  1. enable/disable multiple login using the same username and password to hotspot?
The setting is within the Hotspot Profiles. The default is one concurrent login, but just type in the total amount of logins that you want to allow to be used at the same time under “Shared Users.”
Got it thanks.
