Hotspot 1st login status
hotspot v4.0 - web browser login requires a manual refresh ( i.e 7.0.5730.11) for login status popup to activate and also status page for successful login. Otherwise the login page remains inactive!!!
NB:Popup blocker IS off. Has anyone come accross this and or have a fix?
many thanks
More information is required about your problem.
Do you have MikroTik RouterOS 4.5 version installed? Explain in details, how you login to the HotSpot.
having installed 4.5 this has now fixed the issue. As explained with hotspot 4.0 first login didn’t launch the popup or indicate on main page the website redirect
many thanks
