Hotspot 2.0 ! Wireless 802.11u? Interface wireless interworking-profiles!! A very interesting theme
/interface wireless interworking-profiles
name="5G" network-type=wildcard internet=yes asra=no esr=no uesa=no venue=unspecified hessid=00:00:00:00:00:00 hotspot20=yes
hotspot20-dgaf=yes roaming-ois="" venue-names="" authentication-types="" ipv4-availability=not-available
ipv6-availability=not-available realms="" 3gpp="" domain-names="" operator-names="" wan-status=reserved wan-symmetric=no
wan-at-capacity=no wan-downlink=0 wan-uplink=0 wan-downlink-load=0 wan-uplink-load=0 wan-measurement-duration=0
connection-capabilities="" operational-classes=""
I'm going to mount a mobile hotspot here in my little brasilien town, my Question is what I've to type in this Setup above?
What means hessid=00:00:00:00:00:00 ?
My hotspot login http is http://5g.net/login
authentication-types="http-redirection:http://5g.net name:login"
wan-downlink=0 ?? wan-downlink-load=0?? My hotspot is on bridge!!!
There are a lot of extremly dificult Questions!!
My system is 6.35rc8
MikroTik RouterOS 6.35rc8 (c) 1999-2015 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[ersitizastes@5g.net 0] > int wi
[ersitizastes@5g.net 0] /interface wireless> interworking-profiles
[ersitizastes@5g.net 0] /interface wireless interworking-profiles> pri
0 name="5G" network-type=wildcard internet=yes asra=no esr=no uesa=no venue=unspecified hessid=00:00:00:00:00:00 hotspot20=yes hotspot20-dgaf=yes
roaming-ois="" venue-names="" authentication-types="" ipv4-availability=not-available ipv6-availability=not-available realms="" 3gpp=""
domain-names="" operator-names="" wan-status=reserved wan-symmetric=no wan-at-capacity=no wan-downlink=0 wan-uplink=0 wan-downlink-load=0
wan-uplink-load=0 wan-measurement-duration=0 connection-capabilities="" operational-classes=""
1 name="WanUplink::= 0..4294967295" network-type=wildcard internet=yes asra=no esr=no uesa=no venue=unspecified hessid=00:00:00:00:00:00
hotspot20=yes hotspot20-dgaf=yes roaming-ois="" venue-names="" authentication-types="" ipv4-availability=not-available
ipv6-availability=not-available realms="" 3gpp="" domain-names="" operator-names="" wan-status=reserved wan-symmetric=no wan-at-capacity=no
wan-downlink=0 wan-uplink=0 wan-downlink-load=0 wan-uplink-load=0 wan-measurement-duration=0 connection-capabilities="" operational-classes=""
2 name="WanUplinkLoad ::= 0..4294967295" network-type=wildcard internet=yes asra=no esr=no uesa=no venue=unspecified hessid=00:00:00:00:00:00
3 name="AuthenticationTypeUrl -- string value" network-type=wildcard internet=yes asra=no esr=no uesa=no venue=unspecified
hessid=00:00:00:00:00:00 hotspot20=yes hotspot20-dgaf=yes roaming-ois="" venue-names="" authentication-types=""
ipv4-availability=not-available ipv6-availability=not-available realms="" 3gpp="" domain-names="" operator-names="" wan-status=reserved
wan-symmetric=no wan-at-capacity=no wan-downlink=0 wan-uplink=0 wan-downlink-load=0 wan-uplink-load=0 wan-measurement-duration=0
4 name="https-redir-google" network-type=wildcard internet=yes asra=no esr=no uesa=no venue=unspecified hessid=00:00:00:00:00:00 hotspot20=yes
hotspot20-dgaf=yes roaming-ois="" venue-names="" authentication-types=https-redirection:https://www.google.com ipv4-availability=not-available
I do not understand nothing!!!!!!!!!!!! :confused:
/log print
feb/15 22:58:25 system,info interworking profile added by ersitizastes
feb/15 22:59:09 wireless,info CC:FA:00:B8:83:2A@wlan: disconnected, registered to other device in network
feb/15 22:59:22 dhcp,info dhcp1 deassigned 10.63.194.136 from CC:FA:00:B8:83:2A
feb/15 22:59:22 dhcp,info dhcp1 assigned 10.63.194.136 to CC:FA:00:B8:83:2A
feb/15 22:59:55 dhcp,info dhcp1 assigned 10.63.194.170 to FC:19:10:68:16:30
feb/15 23:00:25 system,info interworking profile <AuthenticationTypeUrl -- string value> added by ersitizastes
feb/15 23:00:58 dhcp,info dhcp1 deassigned 10.63.194.97 from 50:55:27:AE:C0:2D
feb/15 23:01:05 script,error 5g.net 2 Down
feb/15 23:01:30 script,warning 5g.net 2 Up
feb/15 23:04:04 system,info interworking profile added by ersitizastes
After remove all
/log print
feb/15 23:11:59 system,info interworking profile <5G> removed by ersitizastes
feb/15 23:11:59 system,info interworking profile <WanUplink::= 0..4294967295> removed by ersitizastes
feb/15 23:11:59 system,info interworking profile removed by ersitizastes
feb/15 23:11:59 system,info interworking profile <AuthenticationTypeUrl -- string value> removed by ersitizastes
feb/15 23:12:24 wireless,info 64:6C:B2:51:9E:0D@wlan: connected
