Hotspot across routed networks
Hi just wanted some information regarding configuring a hotspot to support a few routed networks.
I currently have a routerboard > Tower AP > CPE > Client AP, the hotspot identifies a connection at the client AP and prompts for a login, any subsequent connection on the same Client AP is allowed passed the hotspot…I don’t want this to happen, I would like any new connection to have to login as well.
fyi - this is not configured in WDS or bridged mode, it’s all routed. So I’m assuming the nat’ing is the issue and the routerboard only see’s one IP for all connections from the Client AP?? I would like to avoid using WDS and or bridging the whole network.
so routerboard interface connected to tower AP is 192.168.1.1, the tower AP is 192.168.1.2 and the CPE is 192.168.1.3 but the Client AP is 192.168.2.1.
Please let me know if you can help me, I’ve been searching and failing miserably.
cheers
Hotspots are based on layer 2 information so you can’t route to them.
http://forum.mikrotik.com/t/hotspot-service-in-routed-network/46383/1
