HotSpot address pool what's the correct settings?!
Hi there,
i had setup three Hotspot servers on my routerboard for three interface ether1, ether2 and ether3. and each ether has DHCP server.
so! the question is: do I have to set address pool for the three Hotspot servers?! or set it “none” ?!
If the correct setting is: address pool(ex.hs-pool), please tell me Why?!
also
If the correct setting is: address pool “none”, please tell me Why?!
thanks
anyone help!
Well I know it is an old port but I also want the answer to this port, please any one help? no one replied to it. Any explanation?
And what does Address pool need to do in Profiles too??
Hi!
https://wiki.mikrotik.com/wiki/Manual:IP/Hotspot#HotSpot_Setup
Address pool for HotSpot network, which is used to change user IP address to a valid address. Useful if providing network access to mobile clients that are not willing to change their networking settings.
I am always set to None. When access points of other vendors are connected to Mikrotik, then clients fall off on them, if a pool is used.
