hotspot = advertise problems [SOLVED]
hi there,
Guys, i just put one hot spot to run, and everything loks fine, except for one point:
does not mather the advertise address i put, the sistem simply redirect it for a strange one (http://189.56.60.8/central/login.php)
can anyone give-me some tip?
i apreciate any help!
Details:
  1. i tested it in one 2.9.5 and 2.9.6 and 3.14 and 4.x router
  2. the internal advertise addresses i put are: : “http://192.168.168.3”, “http://192.168.168.4” and “http://192.168.168.5
    s Sena
    ps: sorry my pour english…
this is so sad…
i download other versions from mikrotik in trial mode.. and i had the same problem over and over…
finily i reset my working server (that has a license) and put the basics for hotspot…
and again i have the exactly problem ..
please any ideas? any tips?
thanks a lot!
s Sena
in the older versions hotspot works completely differently. upgrade to v4.11 and then show us your advertisement configuration
hi there, and ‘Staff’
Everything is OK now, the file ‘alogin.html’ was corrupted.. :frowning: and .. for devil’s reasons is was not updated wen a put new versions…
( good… i cann’t belive it…)
so… i start open files to chech… and this just do not open.
once i replace… everythin works just fine.
in all versions.
s thanks every one!
again, sorry my pour englis!
