Is it possible to use web files from the hard drive you have Mikrotik v3 beta 7 running on. The advertise feature works well if you use links on the internet. I want to be able to pop up web pages from the mikrotik router box itself as if it was not connected to internet. Kinda like a advertising machine only. Can this be done. And is so how would you put your link.
As alternative, you can place all required information to login page, that you need from advertising Internet page.
