Hotspot advertising
Hy all, Anybody knows if there is a problem with hotspot advertising on router RG450g. I activated the advertise option, entered a URL, time… but while i’m navigating on web the advertise page does not POP-UP. Is there other options that i have to do ?
I’m not sure about your advertising configuration. Make sure browser popup blocker does not block the advertisements. It could be better to use alternative approach, modify HotSpot login page and put necessary advertisement information.
I have the same problem. I tryed everything as I found in the Internet. Pop up blocking is off, but nothing happens.
Please if somebody have a solution post it!
Thanks to all people for community support.
i have the same problem.
I use the HotSpot Login by mac. The radius server push the Mikrotik-Advertise-URL and Mikrotik-Advertise-Interval. I have installed the transparent proxy but nothing happens.
Any Ideas?
Regards
EDIT: Workaround: After 3 hours i modify now the file alogin
