HotSpot and cAP ac with RB4011
I’ve got an RB4011 as my main office router, setup fine, all working. I then have a cAP ac wireless access point I want to use to give Staff access and a HotSpot that authenticates against a Radius server.
I’ve had an RB4011 with WiFi integrated working with this same setup, but getting this non-wifi RB4011 and the cAP ac to do the same is proving difficult. Below is my export of config.
What I’ve done is configure the staff wifi to operate as a bridge to the DHCP server on RB4011, then I used the DHCP server on the cAP to give my pool to the hotspot. So my staff wifi works fine, connects, gets and IP from the RB4011 and has internet.
The HotSpot wifi connects, gets and IP address from the 2.1 pool, but doesn’t have internet. It does come up with the login page for the hotspot, but once logged in, still no internet.
Here is my config for the cAP ac, any clues what I’m missing?
# feb/28/2020 16:16:26 by RouterOS 6.43.16
# software id = VD59-56PR
# model = RBcAPGi-5acD2nD
# serial number = B87B0ACC0691
add admin-mac=74:4D:28:AB:15:94 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
    "Grover Hill Staff Wifi " wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=\
    ap-bridge ssid="Grover Hill Staff  Wifi 5g" wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed name="Patron Wifi" supplicant-identity=""
/interface wireless
add disabled=no keepalive-frames=disabled mac-address=76:4D:28:AB:15:96 \
    master-interface=wlan1 multicast-buffering=disabled name="Patron Wifi" \
    security-profile="Patron Wifi" ssid="Patron Wifi" wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
/ip hotspot profile
set [ find default=yes ] dns-name=login.com hotspot-address=192.168.2.1 \
    html-directory=flash/hotspot login-by=https,http-pap
add name=dhcp ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp disabled=no interface="Patron Wifi" name=dhcp1
/ip hotspot
add address-pool=dhcp disabled=no idle-timeout=none interface="Patron Wifi" \
    name="Patron Wifi"
add bridge=bridge comment=defconf interface=wlan2
add interface=ether1 list=WAN
add interface=bridge list=LAN
add address=192.168.2.1/24 interface="Patron Wifi" network=192.168.2.0
add address=192.168.1.252/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    bridge
/ip dhcp-relay
add dhcp-server=192.168.1.1 disabled=no interface=wlan1 name=relay1
add dhcp-server=192.168.1.1 disabled=no interface=wlan2 name=relay2
add address=192.168.2.0/24 dns-server=208.67.222.222 gateway=192.168.1.1 \
    netmask=24
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
/ip hotspot user
add name=admin
add distance=1 dst-address=192.168.1.0/24 gateway=192.168.1.1
add check-gateway=ping distance=1 dst-address=192.168.2.0/24 gateway=\
    192.168.1.1
/system clock
set time-zone-name=America/New_York
/system identity
set name="Grover Hill Wifi"
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
Any thoughts? I’m sure I’m missing something simple but not sure what.
