I have the hotspot feature running for my wireless network. I issue static IP addresses for regular customers and would like to bind the IP address so they can bypass the login screen. When I do this the user will not showup in the hotspot manager for active accounts. Is there a way i can do this to be able to see who is on-line at all times.
Instead of using IP binding to auto authenticate your permanent customers, you can use MAC address authentication.
So, you do this by adding their mac address to the users profile in the username field with no password.
This will then allow you to provide queues and mandwidth management as well as to use the web based usermanagement or other radius authentication system as well as many other things…
my friend, i tried in ip bindigs to add the macc address of clients but, again when i change the ip, he work in internet(type-bypass), if you can explain this ..
man thankyou it worked well, i have just a little problem,i have xx clients, and i have all queues xxx.xx.xx.0/24 , but when i add a hotspot in queues adds a hotspot queue 0.0.0.0/0, and then the queues of clients xxx.xx.xx.0/24 dont work, how can i do to work these queues when i add hotspot server..please help me
DO you want to do bandwidth management for each user or what?
Read the documentation on the subject rate-limit
again in the user profile you just created you can set the bandwidth and busrting that you want to give each customers right there. This will then create the queue dynamically for you automatically…
