I’m running hotspot on my LAN interface
each client have particular profile with bandwidth rate
recently i implemented a local HTTP server and setup a forum on it
i can upload and download file from it with full speed if i use the default profile
if i did not use the default profile i can’t upload or download files fast
for example..
my profile is 256/64 so for normal download from the internet my speed will be 32kb
when i download from the internal server i download with the same speed 32kb
i want to separate the LAN from hotspot to download from internet with 32kb and download from internal server with maximum LAN speed, can it be???
thanks…
and works great internet downloads and uploads are limited by hotspot profiles
LAN upload use full LAN speed
LAN download use full LAN speed only if i downloaded using ftp protocol
when i download using HTTP protocol it limited by hotspot profile
i want to download from LAN with full speed using HTTP
thnx
thats config was work with me very willk but after i upgrade my routr os to 6.0rc12 the ftp server have the same speed for the clint. i need some help plz.
thats my config script:
ip firewall mangle
add chain=prerouting in-interface=LAN_5
dst-address=192.168.200.2 action=mark-packet
new-packet-mark=exempt-up
add chain=postrouting out-interface=LAN_5
src-address=192.168.200.2 action=mark-packet
new-packet-mark=exempt-down
/queue type
add name=exempt kind=sfq
/queue tree
add name=hotspot-exempt-up parent=global-in
packet-mark=exempt-up queue=exempt max-limit=1G
add name=hotspot-exempt-down parent=global-out
packet-mark=exempt-down queue=exempt max-limit=1G
Is the interface ethernet or wireless?
Is your problem the same? Do you want to connect to hotspot interface localnet ips without logging in or bandwidth restrictions?
I try to stdy that problm but I found no global-in or global-out in tab /queue tree i found only global parent the new ver 6.0rc13 !!! is that the Reason of the problm ???
