i dont know if it’s a right place to bring this issue in, i am new to mikrotik, trying my best to prepared my self before my MTCNA/MTCRE , how ever i have configured a hotspot network and load balancing using 2 ISP, after configure load balance the hotspot seems to not forward it’s client to the default login page at the start up like it usually do , please light my path by pointing the mistake, here is my configuration below,
Hotspot was setup using Hotspot setup wizard on interface local
add address=10.50.50.1/24 network=10.50.50.0 broadcast=10.50.50.255 interface=local
add address=192.168.116.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=ISP1
add address=192.168.117.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=ISP2
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=8.8.8.8,8.8.4.4
/ip firewall mangle
add chain=input in-interface=ISP1 action=mark-connection new-connection-mark=ISP1_conn
add chain=input in-interface=ISP2 action=mark-connection new-connection-mark=ISP2_conn
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
add chain=prerouting dst-address=192.168.116.0/24 action=accept in-interface=local
add chain=prerouting dst-address=192.168.117.0/24 action=accept in-interface=local
add chain=prerouting dst-address-type=!local in-interface=local per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=ISP1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=local per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=ISP2_conn passthrough=yes
add chain=prerouting connection-mark=ISP1_conn in-interface=local action=mark-routing new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=local action=mark-routing new-routing-mark=to_ISP2
add dst-address=0.0.0.0/0 gateway=192.168.116.1 routing-mark=to_ISP1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.117.1 routing-mark=to_ISP2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.116.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.117.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=ISP1 action=masquerade
add chain=srcnat out-interface=ISP2 action=masquerade
regards and thanks
