HotSpot and NAT ......
Hi, please sayme if i can setup a network with hotspot and other network only ith NAT in the same interface…i think yes if a disable one to one nat in hotspot but how…
Thnks for assistance.
Dimas
I dont believe this is possible due to the ways how the hotspot feature work… You can try using VLANs and run the hotspot and ‘other network’ on seperate VLANs, but this will require additional hardware to put everything inside the respective VLANs before the traffic gets to your MT…
Simplest option is to just get another interface - it’s not like it’s massively expensive or anything…
C
Yes Savage, it`s the best way but all my wrap boards only have one wireless card, but i found another way, if i use IP binding in Hotspot i can make Dest nat and diferent shaping…for the address that i want.
