i plan to use the Hotspot feature with a central radius based authorization. There will be multiple Hotspot instances in different location connected over some kind of backbone ( Wifi point2point, vpn tunnels … ).
I like to assign fix IPs via radius, but it seems that it’s only possible to assign IPs for the one2one NAT which belongs to direct attached networks.
Is there a way to get a hostroute entry for every running hotspot session. The idea is to redistribute those routes over OSPF and the user can use the same IP in every location.
greetings julian
