Is it possible to have hotspot and pppoe on the same interface?
I have a wireless setup and want some users to login using hotspot and others using pppoe.
Thanks.
Thanks.
HotSpot does not depend in any way on PPPoE or vice versa. So you can simply combine application examples from HotSpot and PPPoE manuals to achieve your goal.
Yes, it is possible.
You can also use same ip pool for both hotspot and pppoe sessions.
