Hotspot and PPPoE
Hi, I have configured the PPPoE and the hotspot on my Mikrotik RB951G-2HnD router on different interfaces, but connected to the same switch only the hotspot works and not the PPPoE, but if I connect on different switches both work correctly. I would like to know how to make both work on the same switch?
By making use of vlans.
For cabled, you will have to do the vlan tagging from client devices, on wireless, you can create 2 separate SSIDs and tag these accordingly
