Hotspot and PPTP
Hi everyone,
I run few hotspots which have been up and running for a while now using RouterOS on a PC, most of them run inside hotels, hostels and block of flats, but a few months ago I started to use outdoor antennas with Mikrotik RouterBoards so my hotspots coverage and usage have grown significantly.
Because I started to have some requests from customers who would like to have a monthly plan I was thinking of using the hotspot for people who just want to buy few hours of use and a WISP kind of authentication and authorization for monthly customers using the same RouterBoards.
For now I’m not planning to install CPE on customers premises I will just use the wireless to make the connections.
I would like to ask you Mikrotik users few questions:
What a WISP normaly uses to authenticate their user to go online?
I believe some people use a kind of vpn on the laptop, but I don’t really know how to set it up.
Could anyone give some help on how to do the configuration on the RB and on the customer’s laptop.
I would really appreciate your help.
Claudio, consider to use WPA or WPA2 with PSK authentication, PSK doesn’t ask for complicated configuration on a client side.
MikroTik router WPA PSK configuration example,
https://www.mikrotik.com/testdocs/ros/2.9/interface/wireless_content.php#4.13.21.7
Communications is not allowed for the client without WPA information.
Hi and thanks for your help.
If I use wpa or wpa2 with psk can I create one key for each customer or laptop? Or it will have to be one key for eveyone?
Yes, it is possible to assign separate PSK key for every user.
Security-profile + Access-list are used on access-point in this case.
