Hotspot and Public IP address
i’d like to make a hotspot but problem occurred.
My configuration is:
PPPOE concentrator/hotspot---- ------- Access point
I created bridge interface (b2) and a tunnel eoip (tunnel)
I set hotspot interface as b2 on PPPOE concentrator, assigned a public IP, dns 0.0.0.0
I assigned wlan1 on Access point as b2 port. Also tunnel is a b2 port.
Hotspot interface is a public ip address and also the pool. But why user can’t open webpage but it’s ok if they put ip address in u.r.l box?
Why their ip in site like myipaddress is the wan ip address interface?
Someone could help me?
Tnx in advance.
Levis
Looks and sounds like dns. Your entries should look something like this:
set primary-dns=xx.xx.xx.xx
set secondary-dns=yy.yy.yy.yy
set allow-remote-requests=yes
They must be valid dns server ips.
ADD: Please do not double post, or in this case, triple post.
Thanks.
I’ ll try tomorrow.
I’ m sorry to double post but they were about different issue and I was wrong because edited the first one.
Anyway sorry again.
At soon,
levis
it doesn’t work!
client can ping and browse internet using ip address but not name like www.google.it.
Thanks in advance.
Levis
If you can ping by ip, but not domain, then it is still dns. Are you using the ip addresses your ISP gave you for dns servers?
I’m using good dns server but not that my ISP gave.
