I have on same mikrotik pppoe server and pool for pppoe, there’s one part of the addresses which are for pppoe users and when those users are connected they get public IP and on net that public IP belong to them, still I only have problems with hotspot
Hello rope..
How are you, other translation at this link: public ip -> internal ip - General - MikroTik community forum
I hope you will get point, and hotspot or pppoe i think is 'tool' for user to connect to the network with valid identity.
good luck...!
Regards
Hasbullah.com
when I disable HotSpot, everything work fine…
Under the Hotspot server settings, set your Address Pool to none and see if that helps.
Ok,...rope....i think this nice forum
I am so sorry,.. ![]()
here, when disable hotspot. how to make print out of money..!
until now we are running on Dedicated lan, hotspot-aaa, pppoe-aaa, and userman as radius server centralized AAA over ethernet and wireless with privite and public ip. all interface in one NIC and WORK FINE too. i like mikrotik...system, but we are not enough time to make exploring more mikrotik features.
Just inform to you: with 'userman-radius-server' v2.9.30 more....easy & friendly
again, so i am so sorry.
regards
Hasbullah.com
I dont use mikrotik DHCP server, so in hotspot none of the pools was not selected.
top
Why aren’t you using the MT DHCP? Try with that and see what happens.
On second thought, since you aren’t using MT’s DHCP, create a valid address pool and set your hotspot to that - this is part of the universal client which might help.
I have two gateways, one is mikrotik (10.10.0.2) for postpaid users and the other one is antamedia (10.10.0.5) for prepaid users. On dhcp server which I use I can set that some mac addresses are using one and some others are using other gateway, but with mikrotik dhcp server that is not possible.
I try to create a valid pool and add him to HOTSPOT server but without results
Hai, Friend
As your first post, i think is correct, you will success add option 'ULDIS' Posted. cause your server is Hotspot server as DHCP for aunt....first.
**Uldis wrote:**Try to disable the transparent proxy in the hotspot user profile and check how it is working.
