How can I limit transfer rate for unauthenticated users in hotspot?
What is rate-limit option in server-prifile for? It creates dynamic simple queue named hs- which doesn’t seem to work at all.
Piotr
Piotr
The hs-server rate limit is the overall limit for that hotspot service.
Each user logged in will have another rate-limit queue that can be set as a default in /ip hotspot users profiles, then assign a profile to a user, or set the default profile.
But it doesn’t work. I set rate-limit to 512kbit/s and then I enabled some web pages for not logged in users. And those users could browse those webs achieving 10Mbits/s and more. How’s that?
Then you haven’t configured it properly - they should get presented with a login page, unless you have mis-configured your walled garden.
Try to run the hotspot wizard or post your config here.
