I want to block some sites (sex, warr, etc.) with web proxy
when set on web proxy and set use transaprennt proxy in user prifle, the block acces function is workin ok
but i have two wan, in the momnet when i set on transparennt proxy work only with master WAN,
any sugestion ?
The better way to do this is by using DNS based blocking you opendns and use 121.246.169.96 this dns blocks all phishing site and harmful websites.
You do this by adding ruls and firewalls then your router becomes busy by filtering request and cause high CPU consumptions and effect router performance.
Birender
