Guys i need a hand…
i have a Hotspot but i put an extender to a building how can I configure the DHCP Server to send the ip adrress to the users that connect into that extender
Please any help will be appreciated
Chris
Guys i need a hand…
Chris
Easy.
In the extender:
Create a bridge and add ether1 and wlans to the bridge.
Add IP to the bridge (THE SAME IP RANGE OF THE HOTSPOT).
link the main AP and the repeater with WDS.
Add the IP+address to ip bindings of the hotspot as bipassed.
I’m having some problems with this as well.
RouterOS v6.1
RB751G-2HnD
The WiFi extender is FRITZ!WLAN Repeater 310
http://www.fritzbox.eu/en/products/FRITZWLAN_Repeater_310/index.php
I don’t think it has any options to create bridges or any such “advanced” options.
You only select the SSID you want to extend and set the security (enter the network key if WLAN is secured).
Here’s the problem:
When connecting to the extender’s WiFi, I get the hotspot’s login page, but the next web page I try to open redirects me back to the hotspot’s login page.
The problem seems to be that the WiFi extender is marked as an active client only for a second or two (sometimes a few more), but then gets removed from the active clients list.
I use the trial login option for the hotspot and the trial-uptime is set to 1h/1s.
I’ve tried making the extender’s IP lease static
/ip dhcp-server lease
add address=10.1.1.2 always-broadcast=yes client-id=1:9c:c7:a6:7e:68:49 mac-address=9C:C7:A6:7E:68:49 server=dhcp1
and adding it to IP Bindings in hotspot’s settings
/ip hotspot ip-binding
add address=10.1.1.2 comment="Fritz repeater 1" mac-address=9C:C7:A6:7E:68:49 server=hotspot1 to-address=10.1.1.2
but there is no difference if this is set or not.
Also, when a client (for example a smartphone) connects to the WLAN via the extender, there is only the extender’s MAC address seen in the MAC table, not the client’s.
Any ideas or tips would be welcome.
If I don’t remember bad…
This gives you 1h of access each second. Then, each second starts another trial.. Then its not working.
Trial is something like:
1h/24h (I give you 1h of Internet each day).
Look in ip/hotspot/hosts for the ip/mac of the fritz, click right button and make binding as bypassed.
Actually, I only want to have users redirected to the “login” page after 1h. I thought the second number (i.e. 1s) was the interval after which the user is allowed to login again.
This setting works perfectly when the clients connect directly to the AP.
I also made the IP binding for the extender.
In any case, I think I managed to solve the problem.
I had 1 IP per MAC setting. After raising this number, it appears that it works as I want to (some more testing required), since the clients connecting via the extender are seen in hosts/active list with the extender’s MAC (but each gets a unique IP now).
Thank you for clarification on the intervals.
