I want to implement hotspot for “Ethernet” that is connected to Access Point as depicted at the image.
DHCP server configured on “Ethernet”.
if I configure Hotspot for “Ethernet”, will Access point unable to access Ethernet2 ?
is this applicable ?
Your graphic and description is confusing. In the graphic, both ports are just labeled “Ethernet”. What is “Ethernet2” that the AP is supposed to “access”?
Then I don’t understand the question at all. Can you give some more details on what you’re trying to do?
If you just want to provide wireless access to the Hotspot configure the AP to bridge the radio into its wired interface. Assign an IP address to the AP. If you need to access the AP administratively add an IP-binding of type ‘bypassed’ for the AP IP address. But that’s a guess at what you’re trying to do.
