Hotspot auth with Radius Throw VPN
at the moment I have mikrotik with hotspot and user identification throw radius. I have some problems with some ISP companies that block the radius protocol and hotspot is working but radius identification fails. I have tried to change the default radius ports but still not working.
I’m thinking if it is possible to build a tunnel with my radius server and then redirect authenticate throw the tunnel.
Anyone can give me a Little bit of light how to do it ? Witch King of vpn you will choose and witch firewall rules i should enable… thanks a lot !
No one has tryied tu add a radius auth throw tunnel ?
Plase help !
Just run RADIUS over an Encrypted tunnel, it should work fine.
