I have a hotspot setup for MAC Authentication against a Radius Server (Works great now, btw!). Now I’m encountering this weird issue :
If I have a user who’s authenticated for a while, some of them will fail to reauthenticate to the hotspot if they’ve timed out. So they get the hotspot page and can’t login, and the only fix I have is to remove them from the active host list. We aren’t doing time based accounting, so my questions is, by removing my idle timeout, do I open myself upto problems ? I can test to see if removing my Idle will fix the problem, But I wanted to make sure that nothing else was really the problem. I will post my hotspot config at the bottom of the post, It will reflect the idle timeout change.
I know that the MT will send interim radius updates for bw accounting, so i’m not worried about not having the session end or anything.
I also have another question : Does the option in the useru profile for Transparent proxy only effect the way the Hotspot works if you are using the proxy packages on the Mikrotik ? Or is it related to the hotspots inner workings ? The manual on this just says :
transparent-proxy (yes | no; default: yes) - whether to use transparent HTTP proxy for the authorized users of this profile
I also know you can set http proxy info for the server profile, is that where its hooked on where its used ?
So while its pretty scarce on info it kindof hints that its for use with the proxy package on the MT.
Thank you for all the help you can provide. ![]()
Hotspot Config’s
[admin@Office-MT] > ip hotspot print detail
Flags: X - disabled, I - invalid, S - HTTPS
0 name=“Office-MT” interface=ether2 profile=Office-MT idle-timeout=none keepalive-timeout=none
ip-of-dns-name=10.10.12.11 name=“Wireless” interface=wlan1 address-pool=hotspot profile=Wireless idle-timeout=none
keepalive-timeout=none ip-of-dns-name=10.10.12.1[admin@Office-MT] ip hotspot profile> print detail
Flags: * - default
0 * name=“Office-MT” hotspot-address=10.10.11.1 dns-name=“login.nebonet.com” html-directory=hotspot
rate-limit=“” http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=mac,cookie,http-chap,trial
http-cookie-lifetime=3d split-user-domain=no trial-uptime=30m/4w2d trial-user-profile=default
use-radius=yes radius-accounting=yes radius-interim-update=5m nas-port-type=ethernet
radius-default-domain=“” radius-location-id=“” radius-location-name=“”1 name=“Wireless” hotspot-address=10.10.12.1 dns-name=“login.nebonet.com” html-directory=hotspot
rate-limit=“” http-proxy=0.0.0.0:0 smtp-server=0.0.0.0/0 login-by=mac,cookie,http-chap,trial
use-radius=yes radius-accounting=yes radius-interim-update=received
nas-port-type=wireless-802.11 radius-default-domain=“” radius-location-id=“”
radius-location-name=“”[admin@Office-MT] ip hotspot user profile> print detail
Flags: * - default
0 * name=“default” session-timeout=3h idle-timeout=4m keepalive-timeout=none status-autorefresh=1m
shared-users=1 transparent-proxy=yes open-status-page=http-login advertise=no1 name=“TrialUser” session-timeout=15m idle-timeout=1m keepalive-timeout=2m status-autorefresh=1m
shared-users=1 rate-limit=“512k” transparent-proxy=no2 name=“hotspot” address-pool=hotspot session-timeout=1h idle-timeout=5m keepalive-timeout=2m
status-autorefresh=1m shared-users=1 rate-limit=“512k” transparent-proxy=noLast Minute Reminder Notes:
Primary Authentication is off of a RADIUS server which controls the HotSpot as well as the DHCP Authentication. Reply’s are Framed-IP-Address and Mikrotik-Rate-Limit. Both work as expected. Users in good account standing should not see the servlet pages as they are mac authenticated.
