Hotspot Auto-login
Hi all,
Can you see if you can help me with the following problem.
Here is basically what we are wanting. We one a make it so when a person opens up their laptop and connects to our wireless network and they open a web browser, they get redirected to a web page(not for authentication or anything like that, just advertisement) and then they can surf to the original page (homepage on their browser or such). The problem is, we don’t want them to have to click “trial” to go to the web page. I know that all you have to do is modify the login.html page to do the automatic log in but I have no idea what the code would be. There is a lot of mikrotik specific stuff in that page and I don’t know what I am doing as far as that goes. Would you happen to know of anyone that would have an example login.html or know what HTML code I need to modify mine? Any help would be appreciated.
Thanks in advance
Dardan
In the HotSpot login page you can set predefined login/password in the login page [which should be correct username/password from ‘ip hotspot user’ menu],
http://www.mikrotik.com/testdocs/ros/2.9/ip/hotspot.php?permalink=0.8110172708293794
