Hotspot Bandwith problem
Hi, I have a problem wiht hotspot, if I assign 8MB to a customer the most he gets is 4 or 5MB, if I make na IP binding for that customer he easily reaches that speed, also if I connect the customer with PPoE he has no problem. It seems that the hotspot has a problem with high bandwith, is there a way to fix this?
how are you giving the customer the 8Mbps?? explain your configuration
Hi, thank you for your reply but I already solved the problem increasing the Queue Size in Queue Types.
Best regards,
