Hi!
Just received my new rb433ah
updated it to the latest stable 3.22
connected some remote access points with eoip tunnels to the bridge and attached a hotspot to this bridge.
when I am looking at the details of connected to the hotspot via eoip hosts I see “Bridge port: Unknown”. Everything else is functioning properly.
I need to know from which bridge port came a customer. How to fix it ? I know, that in 2.9 it worked fine.
Just tried it - have no problems like yours - did you change something in the EoIP settings (MAC address for example) after you add it to the bridge?
thank you macgaiver
problem is solved by changing mac addresses on both ends of eoip tunnels.
