Hotspot Browser Push
I tried to get the Hotspot feature setup on my routerOS. And after I created everything(i think it was everything) I tested the setup and none of the clients who connected got a browser push. Any ideas as to what I did wrong?
If you get IP by the DHCP server probably you have not configured DNS correctly.
Try to configure the static DNS and the domain name
what do I do if there is no domain name for the hotspot server? What if it just has an IP address. Can I simply put that in for the domain name?
You can put simply for example yourname.com or whatyouwant.com
Try to put this and a statics IP DNS.
MT states in the User Manual that when setting up Hotspot either use name for DNS setting or leave blank. DO NOT use IP.
Medube
