HOTSPOT BUG
Hi I made my hotspot with mikrotik 2 years ago. Now I found bug, for many months I search how cause this:
userXX (IP) logged out: traffic limit reached
The problem is the mikrotik has limit to 4.2 GB if the radius has unlimited download quota per day.
Is possible to change that parameter?
From 4.2 GB to 20 GB for fix that?
4,29 GB = 4GiB, it’s overflow of 32-bit counter…
There no option to fix that or make workaround to handle this issue?
If you use freeradius: http://www.netexpertise.eu/en/freeradius/gigawords-support.html
Upgrade your freeradius version or do the modifications.
Regards,
Nikola
