HelloHow to make so that the hotspote was only button to log on to the Internet. without logauta and password?and that should be set up that would give Internet hotspot at 2:0, and then for an hour blocked user who has gone?
thank
thank
you can make this way, under the hotpot, u can enable the trial account, then the profile you can set as you plan…
then when user click login for the trial account, it will as you plan to given the allow on line time to the user .
