Hotspot bypass for repeater stations
Can anyone help with allowing access to repeater stations via winbox.
everything is working 100% except I can’t login to the wds clients, as hotspot does not allow access as they are not logged in.
I need to know how to exclude them from the hotspot authentication process, or permanently allow just those devices to bypass hotspot auth.
Any help would be appreciated.
I have tried walled garden and putting src-address in there, but that does not seem to work.
Put them into “/ip hotspot ip-binding” as type “bypassed”. Though ideally your management IPs should be on a different network than customers, usually you can use VLANs to that effect.
IP bindings worked like a charm thanks.
Will try the vlan option, see how that goes.
Thanks very much!
