I have hotspot set up with aredirect to a remote authentication host. I need to be able to allow one client to bypass the hotspot so he can have free access. Any help would be appreciated.
Greetings!
This is where that is accomplished:
/ip hotspot ip-binding
For IP
/ip hotspot ip-binding add address=xxx.xxx.xxx.xxx type=bypassed
For MAC
/ip hotspot ip-binding add mac-address=yy:yy:yy:yy:yy:yy type=bypassed
These are the simple forms of these entries. Check the docs for full explain.
Will radius accounting records be available for that user?
check documentation for futher explanation
for benseaman…
If you use ip-binding method.. You can access internet or external networks with bypass from hotspot auntentication therefore you do not need to type or input your username and password N if you implement radius server also, so the radius server didn’t record your name, account, ip and the others, because you do not input anythings or information.
regards,
anzay
