I want to use Mikrotik’s hotspot function to redirect all traffic to a local webpage without internet access.
Each time my hotspot can’t reach internet, hotspot redirect won’t work.
What can I do to avoid this? I don’t need internet access.
Here I’ve noticed that has been used a rule to check a gateway http://www.youtube.com/watch?feature=player_detailpage&v=55dGv8QtkYU#t=10s.
Does routse can help me?
That will not work. It is not just a matter of the ip. There is a GET or POST statement in the packet header that specifies the page to be loaded. Chances are most of those will not be in your server.
It was fairly simple to deduce. If I tried accessing a domain name without an internet connection, no go. If I specified an ip address instead, it redirects to the login page.
Edit:You might be able to use some type of regexp in “/ip dns” to return a bogus ip for all domains, but I couldn’t get that to work either.
