Hotspot Config text red - need sulution
Good Day
New here.
I have a RB751U-2HnD and i need to get the hotspot feature working.
At the moment I can access the internet but I cant get the hotspot enabled.
I have created a hotspot interface but the text are in read
Do anyone know what the problem might be?
Any assistance will be apreciated
Create the hotspot again. USE THE WIZARD.
Hai,
I also face the same problem when i setup RB751U-2HnD to enable the hotspot. I create using hotspot wizard and completed but the text are in read, when I connected to the hotspot network, my laptop just connected to internet without popup login page. Please help me cause I already try many times and try other ether port still unsaccesfull. Also read many tutorial to setup the hotspot but still fail.
Thanks in advance…
check hotspot server interface
Can you specific what you mean by check hotspot server? Sorry i am newbie here, this my first mikrotik.
Ok i already check under hotspot server - interface - wlan1. I think the setting corect i set hotspot at wlan1.
Ok what next step…
Surely much too late, but i had once the same.
I turned out that the WLAN was in a Bridge.
P.
