I have a hotspot setup on ver 3.15, and the cookie login works fine with irefox, but not with IE7. When I hit the Logon button, I am returned to the logon page and have to renter my username and password again.
(I have another setup on ver 2.9.41, and IE7 works fine with that version.)
Any ideas what I might be doing wrong?
rgds
Jim Heck
I have tried on the Windows Vista and 3.16 HotSpot.
Setup default HotSpot.
Open IE7 and got login page;
Enter login/password;
removed myself from ‘ip hotspot active’.
Refresh IE7 once again, Cookie was used.
Perhaps you can contact support and send support output file, which will contain the log of your login process [but check it is not related to the particular IE7 configuration].
I have double (triple) checked that my IE7 DOES accepto cookies from other internet sites.
As you suggest, a couple of days ago I sent a description of the problem, plus a supout file to support. I have received an automatic acknowledgement ([Ticket#2008110966000094] Hotspot Cookie Logon) but no human response so far.
I would be very grateful if you could ask support if they are working on this, or if they dont have the resources. If I cant find a solution, I will have to revert to version 2.9, which I know doesnt have this problem.
