I want to set the cookies time to delete for 1 day just for the trail usersNOT FOR REGULAR USERS?
is that possible to do depending on the user for the trail user that begins with ( T- )MAC
Setting in their profile apply only to them. Other users would be using a different profile where the session timeout would be different… Trial users are using a different profile from everyone else, right?
The “profile” setting in “Servers” refers to the “hotspot server profile”, not “user profile”.
Individual users can have any user profile (out of unlimited profiles). When you create a hotspot user, you specify the hotspot server they can login from, as well as their user profile.
Trial users can be of only one user profile though. You can’t have several kinds of trials, but just one kind of trial, and unlimited “normal” user profiles.
That’s Right but I’m using Radius manager for user authentication.
With User Manager, you need to add “group-name” which is the name of a hotspot profile, or alternatively, specify everything in RADIUS, at which point the router will use the default profile for any unspecified values, but use the rest from RADIUS.
like delete the cookies just for the trail user ??? every day>???
That’s what the “Trial uptime reset” setting is for.
Dear
thank you very much for your help
i solved the problem with last update for Mikrotik 6.29.1
the new add
now we can choose a profile just for trail users
