Hotspot CPE device bypass
Hi All,
I am using an R450 and 3 x ubiquity rockets in bridge mode, all CPE’s are in router mode and receive dhcp lease from RB450 and hand out dhcp to LAN side. They are NATed
What im trying to do is figure out how I can allow only the CPE’s to bypass the hotspot. Using IP binding > bypass isnt the correct solution as it bypasses the hotspot authentication completely on some devices allowing open access to the internet.
Is there any kind of way I could by setting up some kind of rules allow just specific access to the CPE ip’s (i was thinking to maybe change the web gui to port 81) and allow access to only those ports an ip’s bypass the hotspot?
