Hotspot crashes, please help
Hi all, I’ve been searching the forums but cant find an answer to my problem. I’ve setup a hotspot on a wds network. everthing works fine for a while then the hotspot crashes and none of the clients have connectivity for about 10 minutes or until i reboot the routerboard with the hotspot. My network is as follows
10.0.0.50 - radius manager
10.0.0.52 - routerboard used for pptp tunnels to hotspots
192.168.1.1 adsl modem
192.168.1.2 tp-link wireless router to first tower
192.168.1.3 wlan1 on first tower
192.168.2.1 wlan2 wds dynamic and hotspot server
192.168.2.2 nanostation connected to wlan2
192.168.2.3 nanostation connected via lan to first nanostation
192.168.2.6 nanostation connected via wifi to second nanostation
192.168.1.4 ether on second tower connected to third nanostation
192.168.1.5 bridge wlan 1+2 wds
my settings on tower 1 are
 ip address export
# nov/22/2011 09:09:22 by RouterOS 5.8
# software id = IGS7-FA9S
add address=192.168.1.3/24 disabled=no interface=wlan1 network=192.168.1.0
add address=192.168.2.1/24 disabled=no interface=bridge1 network=192.168.2.0
interface wireless export
# nov/22/2011 09:12:36 by RouterOS 5.8
set default authentication-types="" eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m interim-update=0s management-protection=disabled \
    management-protection-key="" mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=\
    disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none \
    static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=""
add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm group-key-update=5m interim-update=0s management-protection=allowed \
    management-protection-key="" mode=dynamic-keys name=profile1 radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no \
    radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none \
    static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" \
    static-transmit-key=key-0 supplicant-identity="" tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=lizzard0923 \
    wpa2-pre-shared-key=lizzard0923
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2ghz-b basic-rates-a/g=6Mbps basic-rates-b=\
    1Mbps bridge-mode=enabled burst-time=disabled channel-width=20mhz compression=no country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 \
    frequency=2412 frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=00:0C:42:C9:6B:BC max-station-count=2007 mode=station mtu=1500 name=wlan1 \
    noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 nv2-security=\
    disabled on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 \
    radio-name=000C42C96BBC rate-selection=legacy rate-set=default scan-list=default security-profile=profile1 ssid=EGH-T1 station-bridge-clone-mac=\
    00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 \
    tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
    disabled wireless-protocol=unspecified wmm-support=disabled
set 1 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" arp=enabled band=2ghz-b/g basic-rates-a/g=6Mbps basic-rates-b=1Mbps bridge-mode=\
    enabled channel-width=20mhz compression=no country=no_country_set default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 \
    default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=2442 \
    frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any ht-rxchains=0 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,\
    mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0 hw-fragmentation-threshold=disabled \
    hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=00:0C:42:67:01:1E max-station-count=2007 mode=ap-bridge mtu=1500 \
    name=wlan2 noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 \
    nv2-security=disabled on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=\
    post-2.9.25 radio-name=000C4267011E rate-selection=legacy rate-set=default scan-list=default security-profile=default ssid="Edenglen WIFI" \
    station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=bridge1 \
    wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic wireless-protocol=unspecified wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-\
    1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-\
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=\
    no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
    streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default \
    rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
add dns-name=wifi.egh.co.za hotspot-address=192.168.2.1 html-directory=hotspot http-proxy=127.0.0.1:8080 login-by=http-chap,http-pap name=hsprof1 \
    nas-port-type=wireless-802.11 radius-accounting=yes radius-default-domain="" radius-interim-update=5m radius-location-id="" radius-location-name="" \
    radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
/ip hotspot
add address-pool=hs-pool-4 addresses-per-mac=2 disabled=no idle-timeout=5m interface=bridge1 keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip hotspot ip-binding
add address=10.0.0.1 disabled=yes to-address=10.0.0.254 type=bypassed
add disabled=no mac-address=00:0C:42:67:01:1E type=bypassed
add disabled=no mac-address=00:27:22:2C:22:6D type=bypassed
add disabled=no mac-address=00:27:22:2C:22:1D type=bypassed
add disabled=no mac-address=00:27:22:2D:1F:92 type=bypassed
add disabled=no mac-address=00:0C:42:C9:6A:94 type=bypassed
add disabled=no mac-address=00:0C:42:C9:6A:93 type=bypassed
add disabled=no mac-address=00:0C:42:67:01:0A type=bypassed
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add disabled=no name=buzz password=test profile=default
/ip hotspot walled-garden
add action=allow disabled=no dst-host=buzzconnect.dyndns.org*
 ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          192.168.1.1               1
 1  DS  0.0.0.0/0                          10.0.0.52                 1
 2 A S  10.0.0.0/24                        edenglen-test             1
 3 ADC  10.0.0.52/32       192.168.2.1     edenglen-test             0
 4 ADC  192.168.1.0/24     192.168.1.3     wlan1                     0
 5 ADC  192.168.2.0/24     192.168.2.1     bridge1                   0
 ip firewall nat print all
 0 D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
 1 I chain=hotspot action=jump jump-target=pre-hotspot
 2 D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
 3 D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
 4 D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst dst-port=80
 5 D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst dst-port=443
 6 D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
 7 D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
 8 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
 9 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
10 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
11 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp dst-port=443
12 I chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
13 D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
14 I chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
15 X ;;; place hotspot rules here
     chain=unused-hs-chain action=passthrough
16   chain=dstnat action=redirect to-ports=8080 protocol=tcp dst-port=80
17   ;;; masquerade hotspot network
     chain=srcnat action=masquerade src-address=192.168.2.0/24
