Hotspot Detecting MACs inside of client Network and registering as hosts
Hi all,
I Have the following set up. AP= (Basebox5) NV2- AP Bridge. Client (SXT) Station with simple Masquerade NAT to client network - All ROS versions
I have to add a rule in the AP Hotspot IP bindings table to block the IP address range on the client SXT Lan side (192.168.0.0/24) otherwise I get multiple Hosts appearing binding to the client Lan address range
The SXTs are allocated WAN ip address´s by DHCP server in the AP
Anybody know of a way I can stop this happening? I am guessing it is related to the Nat mechanism in the client SXT.
Mos probably is due to the station mode used at the client SXT. See http://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes
Are wlan1 and ether1 interfaces bridged on client SXTs? Have you tried wireless mode = station?
Client sxt are simple routers with nat not bridged. Wireless mode is Station
