Version 2.8.22
128 megs of ram
Celeron 667
64 meg flash
4 port Dlink ethernet card
I had the DHCP hotspot working fine and someone just told me it stopped working so I checked it and the DHCP server for the hotspot is marked
I for invalid.
The POOL still exists and the Interface works and has the proper IP address on it but it still will not change status. I have disabled and re-enabled the interface and it just comes backs invalid.
The have removed the DHCP server and setup it back up and it says the same thing again. Invalid.
ANY IDEAS?
NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 wireless_dhcp wireless wireless 1d yes
1 suite_500 suite_500_dhcp_vlan55 dhcp_suite_500 10d yes
2 vivato_dhcp eoip_to_exo vivato_dhcp_pool 10h yes
3 I hs-dhcp-server hotspot_port1
hs-pool-real 5h no
Tim
UPDATE
Well I figured out why it says invalid but not WHY it says.
The Interface for the hotspot was also ina bridge group with a vlan and it did not like that. I dont know why but it did not. I took the bridge out and it is working now. What a pain. Does anyone know what the problem is?
